SNR Reset
- SNR Reset
SNR Reset
11-04-2013 8:03 PM
Download SN Margin has risen to 11.9 from around 6 after I disconnected the modem yesterday, so please perform an SNR reset.
jim:red All caps in title changed mod:end
Re: SNR Reset
11-04-2013 8:37 PM
Have you been doing a lot of fiddling and several disconnects in a short time
If you haven't then a reason needs to be found otherwise it is unlikely that Plusnet will agree to do it specially if you had one
I suspect that your problem (from the linked thread) has come back
Edit - I got the time wrong
Re: SNR Reset
12-04-2013 9:25 PM
The last time I had the SN margin go up which was a couple of months ago PN performed a re-set which returned things to normal (requested through this forum).
Please try not to be condescending Oldjim.
Re: SNR Reset
13-04-2013 12:36 AM
Re: SNR Reset
15-04-2013 11:02 AM
It does look like it's been caused by errors on the line, the quality is currently showing as Red (as opposed to amber or green) and the target SNR margin has indeed been raised to 12dB.
Resetting the SNR at this point would do more harm than good and would cause the line to retrain at a much lower speed. Is there anything that could be causing the errors? Router not in master socket, faulty filter, anything new added to the line?
Re: SNR Reset
15-04-2013 2:54 PM
It is connected to the master socket and nothing has been changed, it has all happened since I disconnected through the router to tidy the wiring up.
The line had been very stable and I'm sure before this it had stayed connected for twenty odd days.
Re: SNR Reset
15-04-2013 4:10 PM
Quote from: grahamholmes The line had been very stable and I'm sure before this it had stayed connected for twenty odd days.
Was that after the wiring had been tidied? Just wondering if something unforseen could have happened while that was going on.
Re: SNR Reset
15-04-2013 4:38 PM
@grahamholmes
What "tidying up" exactly have you done to the wiring? - That obviously constitutes "a lot of fiddling" in Jim's book
Assuming things haven't changed - can you confirm you are on 20CN, using the 582n and could you check the firmware version?
Does your 582n have a USB port and if so, are you using it?
Re: SNR Reset
15-04-2013 4:54 PM
Re: SNR Reset
15-04-2013 6:04 PM
Re: SNR Reset
18-04-2013 3:52 PM
I disconnected through the modem as I have done in the past.
The line seems stable now and I have had no disconnects for over 2 days.
20CN at exchange although 21CN is supposed to be coming soon any dates on this PN?
Router is TG582n
Software version 8.4.4.J
Not using a USB port
Re: SNR Reset
18-04-2013 4:30 PM
The estimated date at the moment is: 31/07/2013. This may be subject to change though.
Re: SNR Reset
18-04-2013 8:20 PM
Quote from: grahamholmes The line seems stable now and I have had no disconnects for over 2 days.
If it's not disconnections it's going to be excessive errors. Could you post the errors counts (make sure you also give the connected time so we know how long they were over).
Re: SNR Reset
18-04-2013 10:19 PM
DSL Type: ITU-T G.992.1
Bandwidth (Up/Down) [kbps/kbps]: 448 / 3.968
Data Transferred (Sent/Received) [MB/GB]: 148,77 / 1,99
Output Power (Up/Down) [dBm]: 12,1 / 19,8
Line Attenuation (Up/Down) [dB]: 30,5 / 46,5
SN Margin (Up/Down) [dB]: 21,0 / 12,0
Chipset Vendor ID (Local/Remote): BDCM / TSTC
Loss of Framing (Local/Remote): 717 / -
Loss of Signal (Local/Remote): 81 / -
Loss of Power (Local/Remote): 0 / -
Loss of Link (Remote): -
Error Seconds (Local/Remote): 890 / -
FEC Errors (Up/Down): 0 / 22.865
CRC Errors (Up/Down): 0 / 2
HEC Errors (Up/Down): - / 2 / 4
Re: SNR Reset
18-04-2013 10:40 PM
However there is one slightly worrying thing - the downstream attenuation is rather high compared to the downstream (normally the downstream is about half the upstream)
This may indicate a line fault or external interference but I am guessing here
