SNR Reset
- Re: SNR Reset
SNR Reset
24-01-2012 12:38 PM
Hello,
Over past few days I've had a few connection drops, now my speed has dropped from nearly 8mb to under 5mb. and my SN target seems to be 11db (I understand this would loose me over 2000kb sync)
I've since replaced all the old in-house wiring (Pre Post Office!!) and would like an SNR reset to see if I can attain a stable higher speed.
Could somebody here please action this?
Heres my stats if you need them (SN margin seems high?)
Output Power (Up/Down) [dBm]: 12.5 / 18.5
Line Attenuation (Up/Down) [dB]: 25.5 / 43.5
SN Margin (Up/Down) [dB]: 25.5 / 11.0
Loss of Link (Remote): 0
FEC Errors (Up/Down): 0 / 0
CRC Errors (Up/Down): 32 / 195
HEC Errors (Up/Down): 7 / 439
Thanks a bunch
Thanks a bunch
Message 1 of 6
(981 Views)
5 REPLIES 5
Re: SNR Reset
24-01-2012 12:45 PM
Hi leeroyian,
I'll certainly give it a go. Just remember that it'll start a new 10 day training period and can take 24 hours to take effect.
Jojo
Jojo
Message 2 of 6
(472 Views)
Re: SNR Reset
24-01-2012 12:58 PM
Thanks Jo! Will I need to reboot the router or anything?
Message 3 of 6
(472 Views)
Re: SNR Reset
24-01-2012 1:05 PM
No, it'll drop the session from there
Message 4 of 6
(472 Views)
Re: SNR Reset
24-01-2012 1:24 PM
For anyone who's following this
Since Jo done the reset my stats are now back to normal.
Output Power (Up/Down) [dBm]: 12.5 / 19.5
Line Attenuation (Up/Down) [dB]: 25.5 / 43.0
SN Margin (Up/Down) [dB]: 24.0 / 6.5
Speed now back up to 6904kbps
Plusnet is awesome! Thanks again Jo
Message 5 of 6
(472 Views)
Re: SNR Reset
24-01-2012 1:47 PM
Aw, great news, thanks for letting me know
Message 6 of 6
(472 Views)
