SNR Reset request
dydcheung
SNR Reset request
Would the folks here kindly do an SNR reset for my line?
I've seen a drop in my speeds since a friend of mine inadvertently plugged in a voltage converter into the same outlet as my router.
Thanks in advance!
Fixes: 149
Re: SNR Reset request
Hi there
I've just reset the line for you now. Give it 4 hours and that should go through
Any further issues please let us know
 Matthew Wheeler
dydcheung
Hello! I recently have had an issue with my speeds dropping quite significantly without any apparent changes to my side of things. Could a SNR reset help to change this?
dydcheung
If it helps, here are my latest router stats.
dydcheung
dydcheung
Bump
Fixes: 46
I can see that the connection is stable so an SNR reset would help in this instance.
Please allow up to 24 hours for that to take effect.
 Adam Walker
