SNR Reset request
- Re: SNR Reset request
SNR Reset request
30-05-2014 10:37 PM
Would the folks here kindly do an SNR reset for my line?
I've seen a drop in my speeds since a friend of mine inadvertently plugged in a voltage converter into the same outlet as my router.
Thanks in advance!
Thanks in advance!
Message 1 of 7
(1,212 Views)
6 REPLIES 6
31-05-2014 9:29 AM
Message 2 of 7
(615 Views)
06-01-2016 12:18 PM
Hello! I recently have had an issue with my speeds dropping quite significantly without any apparent changes to my side of things. Could a SNR reset help to change this?
Message 3 of 7
(615 Views)
06-01-2016 12:31 PM
If it helps, here are my latest router stats.
Message 4 of 7
(615 Views)
06-01-2016 7:11 PM
Some updated stats.
Message 5 of 7
(615 Views)
07-01-2016 11:43 PM
Bump
Message 6 of 7
(615 Views)
08-01-2016 4:55 PM
Message 7 of 7
(615 Views)
