SNR Reset needed?? -- update
- SNR Reset needed?? -- update
Re: SNR Reset needed?? (Annoyed now!!!)
26-04-2013 8:44 PM
It seems insistent on keeping my line at 3dB when its not as stable as 6dB. I would much prefer 6dB. Is there any way of fixing my margin at 6dB at all, or can I fiddle with the technicolour router to fix it at 6dB. Unsure if the DMT tool will work with this router.
Resync stats...
Apr 25 23:55:29 xDSL linestate up (ITU-T G.992.5; downstream: 7876 kbit/s, upstream: 888 kbit/s; output Power Down: 18.9 dBm, Up: 12.8 dBm; line Attenuation Down: 44.5 dB, Up: 24.6 dB; snr Margin Down: 3.2 dB, Up: 12.8 dB)
Whats my Line profile please currently, and can anyone from the digi care team try and find out why the DLM insists on keeping me at 3dB
26-04-2013 9:29 PM
The command for that is: xdsl config adslmultimode=adsl2
To go back to ADSL2+ it's adsl2plus
26-04-2013 10:05 PM
Request that you be moved to ADSL1 with the upload uncapped
On ADSL1 I don't believe that the 3dB option exists
27-04-2013 1:18 AM
27-04-2013 9:12 AM
27-04-2013 9:18 AM
Quote from: Anotherone If you set it in the modem/router, you can change it any time.
How do you set it in the router, dmt tool dosnt work with the technicolor... Am happy to give cli commands a go, if there is an option to do that. I presume doing this would be like dmt and not survive reboots...
27-04-2013 9:25 AM
27-04-2013 9:36 AM
27-04-2013 9:41 AM
Page 856 is where I got the information I posted in reply #16
27-04-2013 9:42 AM
27-04-2013 9:45 AM
27-04-2013 9:59 AM
27-04-2013 10:19 AM
xdsl maxspeed [rx = <number>] [tx = <number>]
If you reduce the speed, that might increase the stability and noise margin.
27-04-2013 11:02 AM
Quote from: Oldjim There isn't and you can't but that isn't what we are trying to do
Perhaps, but it seemed to refer to the following posts:
Quote from: penfold I would much prefer 6dB. Is there any way of fixing my margin at 6dB at all, or can I fiddle with the technicolour router to fix it at 6dB. Unsure if the DMT tool will work with this router.
Quote from: penfold How do you set it in the router, dmt tool dosnt work with the technicolor... Am happy to give cli commands a go, if there is an option to do that. I presume doing this would be like dmt and not survive reboots...
which are definitely setting the SNRM
27-04-2013 11:05 AM
Quote from: Oldjim Given your attenuation there is one option
