SNR Reset Request
DougMa
SNR Reset Request
I recently swapped-out my microfilters for a filtered faceplate and switched to a better modem. I've waited a couple of weeks but DLM hasn't adjusted my SNR margin despite the line now being stable.
Please could you reset the SNR margin for me?
Many thanks,
Doug
Fixes: 65
Re: SNR Reset Request
I've just submitted the SNR reset for you.
Keep us posted.
 Adam Walker
DougMa
Thanks Adam, I'll feed-back once it takes effect!
DougMa
Woohoo!  Up from 1.8 to 3Mbps  Grin
The current Downstream BRAS rate is: 2.96 Mbps
The current Upstream BRAS rate is: 0.83 Mbps
Now I just need to wait for the Plusnet Profile to adjust.
Plusnet Staff
Plusnet Staff
Fixes: 5
No need to wait - I've just changed that for you now. You should notice an improvement shortly Smiley
Chris Pettitt
Cloud Environments Engineer
DougMa
Thanks Chris.
I just checked and my BRAS is still 2.96Mbps, but the Plusnet profile has only moved from 1.8 to 1.9Mbps!  I guess I need to wait for the next delta report to be processed?
Plusnet Staff
Plusnet Staff
Fixes: 5
Sorry about that, I've just changed it again. That should do the trick.
Chris Pettitt
DougMa
Perfect, and the router held the sync overnight so I'm hopeful the faceplate+router changes did the trick.
Thanks for the help.
