SNR Reset Request
Lee0101
SNR Reset Request
I had some problems with filters causing resyncs recently and the line should be stable now but the DLM hasn't automatically reverted so can i have the SNR reset back to 6db please?
Thanks,
Lee
Plusnet Staff
Plusnet Staff
Fixes: 5
Re: SNR Reset Request
Hi Lee,
That's been submitted for you.
Chris Pettitt
Cloud Environments Engineer
Lee0101
Thanks Chris.
Lee
