SNR Reset Please
ianfretwell
SNR Reset Please
Could I please request that my SNR be reset back to 6.
I'm aware that the line will be showing quite a few drops in connection of late - however - the vast majority of those are caused by myself changing wiring within the house and experimenting with firmware and associated settings on my router.
I am able to force the force (Draytek 2860) to lower the SNR margin by  factor of 5dB (thats the max it allows) - so I can get it down to 7dB and get an additional 4 to 5Mbs connection link speed - the line remains as stable at that setting as it does at it's current 12dB.
So I was hoping somebody could help me achieve this ?
Many thanks,
Ian
Fixes: 10
Re: SNR Reset Please
Make sure you don't do any more disconnects so they can see it has been stable since you stopped messing!
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
Fixes: 165
I can put this through, however I do have concerns based on these line stats:
  Upstream DSL Link Information Downstream DSL Link Information
Loop Loss: 11.3 26.5
SNR Margin: 6.5 12.3
Errored Seconds: 0 1
HEC Errors: 0
Cell Count: 152216 264205
Speed: 1103 13452
Maximum Stable Rate (KBPS): 17024 Fault Threshold Rate (KBPS): 13619
Mean Time Between Retrains (Seconds): 86400 Mean Time Between Errors Upstream (Seconds): 1838
Indicative Line Quality: A Mean Time Between Errors Downstream (Seconds): 25
Reducing the SNR is likely to make that drop lower and therefore more errors. Let me know if you'd still like me to go ahead though.
 Chris Parr
 Plusnet Staff
ianfretwell
Hi Chris,
If you could I'd be grateful. I assume that DLM will force it back up again if it proves to be unsuitable ?
Thanks,
Ian
Fixes: 165
That's been put through for you. Yes, the DLM should increase the SNR again if needed.
 Chris Parr
 Plusnet Staff
ianfretwell
Many thanks Chris - much appreciated.
