SNR Reset Please
- Re: SNR Reset Please
SNR Reset Please
19-10-2016 9:30 AM
Could I please request that my SNR be reset back to 6.
I'm aware that the line will be showing quite a few drops in connection of late - however - the vast majority of those are caused by myself changing wiring within the house and experimenting with firmware and associated settings on my router.
I am able to force the force (Draytek 2860) to lower the SNR margin by factor of 5dB (thats the max it allows) - so I can get it down to 7dB and get an additional 4 to 5Mbs connection link speed - the line remains as stable at that setting as it does at it's current 12dB.
So I was hoping somebody could help me achieve this ?
Many thanks,
Ian
19-10-2016 10:28 AM
Make sure you don't do any more disconnects so they can see it has been stable since you stopped messing!
19-10-2016 12:21 PM
I can put this through, however I do have concerns based on these line stats:
Upstream DSL Link Information | Downstream DSL Link Information | |
Loop Loss: | 11.3 | 26.5 |
SNR Margin: | 6.5 | 12.3 |
Errored Seconds: | 0 | 1 |
HEC Errors: | 0 | |
Cell Count: | 152216 | 264205 |
Speed: | 1103 | 13452 |
Maximum Stable Rate (KBPS): | 17024 | Fault Threshold Rate (KBPS): | 13619 |
Mean Time Between Retrains (Seconds): | 86400 | Mean Time Between Errors Upstream (Seconds): | 1838 |
Indicative Line Quality: | A | Mean Time Between Errors Downstream (Seconds): | 25 |
Reducing the SNR is likely to make that drop lower and therefore more errors. Let me know if you'd still like me to go ahead though.
19-10-2016 12:51 PM
Hi Chris,
If you could I'd be grateful. I assume that DLM will force it back up again if it proves to be unsuitable ?
Thanks,
Ian
19-10-2016 1:01 PM
That's been put through for you. Yes, the DLM should increase the SNR again if needed.
19-10-2016 1:03 PM
Many thanks Chris - much appreciated.
