SNR Margin high and very slow speed
GarryB62
Hello, hope you can help.  Yesterday evening my broadband started to drop frequently, it would connect then disconnect every minute.  It did this for hours.  I'm on very old ADSL 1 technology but my line is normally quite stable.
I woke up this morning to find the speed had dropped to around 2mbps which is almost unusable, with a SNR margin of 24.6.  Normally this would be around 6db.
I was tempted to reset the router again tonight; however I didn't want to make things worse so BT thought I had another line drop.
Is it possible someone could look into this and maybe do a DLM reset for me, as I don't really want to go through the weekend with such slow speeds and wait for the line profile to recover (up to 72 hours if I'm correct)?
Many thanks!
1 REPLY 1
Fixes: 334
Re: SNR Margin high and very slow speed
@GarryB62 With an SNR figure as high as that, I sincerely doubt a 'DLM reset' will sort it. I suggest you follow the below:
If the phone test passes, report a broadband problem via: https://www.plus.net/help/report-a-problem/broadband/
The above assumes you still have 'normal' landline connection - if you have a SOGEA (internet only) one, just use the second link to report a network issue.
