SNR Change Please
davidfriedlande
SNR Change Please
Can someone please change my snr to 3db?
i have a very stable connection. I usually set my router to tweak from 6 to 3 but for some reason it is not making any changes today after an unexpected power cycle.
adie:orange removed all caps title as per link:rules
14 REPLIES 14
adamwalker
Fixes: 221
Re: SNR Change Please
I'm fine with that as it's currently about 4.5db
You should see that go through in the next few hours.
Please drop us a reply back here should it case any issues.
 Adam Walker
davidfriedlande
Thanks Adam but there has been no change at all
Pettitto
Fixes: 5
I've just resubmitted that for you, you should notice a difference within the next hour or so.
davidfriedlande
I did notice a difference! Internet stopped working completely since the 22. No DSL light and no sync. For the first time I'm not happy with plus net at all. Told on the phone 3 days to fix minimum.
Pettitto
Fixes: 5
I'm sorry this has happened.
I think you'd be best keeping your SNR Target at 6db, it looks as though your line isn't happy syncing at 3db. I've requested this change manually to see if it'll bring the sync back up, if it doesn't we'll continue to investigate.
davidfriedlande
Still not working
Pettitto
Fixes: 5
It's not gone through yet. I'm awaiting our suppliers to complete this.
davidfriedlande
When though? I have had no service since Thursday!
Pettitto
Fixes: 5
It's gone through but doesn't appear to have brought the service back up - I'm really trying to help you.
I'll leave the Fault Ticket with the Faults Team as I can see they now have this in hand.
davidfriedlande
Finally up and running again! thanks for everyones help getting this sorted, 1 last thing bt profile is:  IP Profile for your line is - 8.93 Mbps
PN Profile: Current line speed: 7.6 Mb
Pettitto
Fixes: 5
I've updated it.
davidfriedlande
thanks Chris, i was told the engineer needed to come to my house, no one came but after a random reboot of router my internet came back online, i presume he just went straight to the cabinet and fixed something there.
Pettitto
Fixes: 5
There aren't any notes from the engineer yet, so I'm not sure.
The Faults Team will include the notes from the engineer when they retest your line to ensure everything is working.
davidfriedlande
about 30 mins after my last post openreach called me to inform me the engineer will be on his way soon as his current job is taking longer than expected!
therefore my problem seems to have magically fixed itself without any intervention from the engineer. V strange indeed.
They were quite willing to still come round and check things but i thought it wasnt worth it, in hindsight i probably should have still got them round....
