SN Margin Change
- SN Margin Change
SN Margin Change
08-11-2010 5:07 PM
I have had a couple of overnight resyncs in the last 18 days. The sync speed dropped from 2368 to 2304 to 2080 all with a SN Margin about 6.5.
Having read many items on removing the bell wire, I thought I'd give it a go.
There was no interruption to my connection but I note that the SN Margin has shot up to 14.0! Nothing else has changed.
Has anyone else experienced such a change and could anyone explain why this has happened?
Re: SN Margin Change
08-11-2010 5:14 PM
Assuming you did manage it a resync should give a significantly faster speed
08-11-2010 5:22 PM
08-11-2010 5:23 PM
08-11-2010 5:26 PM
08-11-2010 5:32 PM
08-11-2010 5:36 PM
08-11-2010 5:37 PM
08-11-2010 5:43 PM
Quote from: Oldjim Assuming you did manage it a resync should give a significantly faster speed
09-11-2010 10:33 AM
I removed the bell wire & earth from the extension socket this morning and switched the router off for 30 minutes.
On restart the sync speed had gone from 2080 to 3744 and the SN Margin had gone from 14.0 to 6.0.
Its looking good - just a 3 day wait for DLM to catch up and then, hopefully, I'll crack open the champagne!!
12-11-2010 12:12 PM
This morning, my BT IP Profile has gone from 1750 to 3000. This has been mirrored by PN.
The result - my download speed has increased from 1500 to 2576.
Given my original estimate of 2.5Mbps, I think my Broadband problems are now sorted. Long may it last!!
