SMTP servers
- SMTP servers
SMTP servers
07-04-2008 1:20 PM
Is there any alternative way of sending outgoing mail under those circumstances. Is there another port one can use or a way of accessing the Plusnet SMTP server directly ?
All I can ever do is to use webmail to send replies and then move my reply to my webmail inbox, download my reply using Outlook and finally file it under "Sent", which is a workaround, but a bit cumbersome. I am looking ideally for a fix, not a workaround !
TVM.
Re: SMTP servers
07-04-2008 1:22 PM
Re: SMTP servers
07-04-2008 1:34 PM
Re: SMTP servers
07-04-2008 3:24 PM
What does "Authenticate using your username (not username+mailbox)" mean exactly ?
Does this mean in Outlook under Tools>Services>Servers>Server Information, I enter "relay.plus.net" as usual, and then under Outgoing Mail Server tick the box which asks "My server requires authentication" ?
I hope so !
Thanks again.
Re: SMTP servers
07-04-2008 3:28 PM
Quote Does this mean in Outlook under Tools>Services>Servers>Server Information, I enter "relay.plus.net" as usual, and then under Outgoing Mail Server tick the box which asks "My server requires authentication" ?
Yes, but it also means that you have to enter the user name and password that you use to log into the member centre and NOT the username and password assosciated with any additional mailboxes you've set up on your account. This applies regardless of the e-mail account you're sending from (i.e. relay.plus.net must always see your member centre credentials).
On the settings page for the outgoing server it's best to untick the box that says "use the same details as my incoming server" (or similar) and enter your username and password in the boxes provided.
Also DO NOT tick any boxes which say "Log in using secure password authentication (SPA)".
Re: SMTP servers
07-04-2008 3:29 PM
Re: SMTP servers
07-04-2008 3:36 PM
That seems to be the solution and I will try it next time I am away. To think I have been messing around changing the SMTP server to the third party ISP or using webmail all this time. This will really make a big difference to me (especially when cruising around to hi-jack some unsuspecting stranger's unprotected WiFI connection in the middle of the night, running the risk of being apprehended for curb crawling :-[).
Thanks very much indeed.
Re: SMTP servers
07-04-2008 3:38 PM
Re: SMTP servers
07-04-2008 3:40 PM
Re: SMTP servers
07-04-2008 3:47 PM
Re: SMTP servers
07-04-2008 3:51 PM
Re: SMTP servers
07-04-2008 4:01 PM
Re: SMTP servers
07-04-2008 4:18 PM
Re: SMTP servers
07-04-2008 5:06 PM
I use ws_ftp95.ex which is the original ftp software which Plusnet recommended donkeys' years ago. It serves my purposes although no doubt there are better ways to do it these days. The server is shown simply as ftp.plus.net followed by my user name and ID. This only works from my home connection, and when travelling, I always have to use dial-up to access it.
So what am I doing wrong. How do I ftp to www/homepages ?
Re: SMTP servers
07-04-2008 5:44 PM
I would try another FTP client, or even the built in DOS one as there is no restriction accessing ftp.plus.net.
