SMS messages for Faults updates delayed
- SMS messages for Faults updates delayed
08-06-2009 1:07 PM
There seems to be some delay in the system for the SMS updates being dispatched.
Whilst I have no complaint whatsoever about the help received from both James and Richard which was excellent, the initial message was 4hrs after the instigation of the fault and a later message that night arrived 7 3/4 hrs later @0700 the following morning.
Whether the delays were in your provider's message centre or at PN itself I don't know. I have assumed it wasn't my end as other text messages received both days had no delay. You may want to have a look to see if there's a bug in the system.
What makes this slightly amusing in my case was the fact that Openreach had the Fault fixed (at my rural exchange) within an 1 1/4 hrs of report I don't what Richard said to them to get them to move so fast, mind you, so they should have, as the fault was caused by one of their 'engineers' being somewhat clumsy earlier in the day (and whose mug I shall not forget in a hurry after the porky pies he told me ).
Anyway, thanks again to James and Richard.
Message 1 of 3
(670 Views)
2 REPLIES 2
Re: SMS messages for Faults updates delayed
08-06-2009 1:08 PM
Hi Chris,
As per my PM to you, this should be fixed now.
Glad your phone line was fixed nice and quickly.
Message 2 of 3
(325 Views)
08-06-2009 9:00 PM
not in my case, the fault was in the Ilford Node and was cleared in my case at about 10:30 on Sat, http://usertools.plus.net/status/archive/1244288074.htm refers.
My first sms was on Sunday Morning, and the timing on the incident report was
first SMS received 7-6-09 At 09:47:02, closely followed by another At 9:48:02
e-mails were slow
first
Delivery-date: Mon, 08 Jun 2009 13:07:43 +0100
Received: from [212.159.7.33] (helo=mx.ptn-ipin01.plus.net)
by fhw-inmx14.plus.net with esmtp (PlusNet MXCore v2.00) id 1MDDc9-0006rg-Cg
for postmaster@pierre.me.uk; Sun, 07 Jun 2009 09:20:25 +0100
second in reply to my moans
Delivery-date: Sun, 07 Jun 2009 18:55:55 +0100
Received: from [212.159.7.34] (helo=mx.ptn-ipin02.plus.net)
by fhw-inmx06.plus.net with esmtp (PlusNet MXCore v2.00) id 1MDMb5-0005kW-8T
for postmaster@pierre.me.uk; Sun, 07 Jun 2009 18:55:55 +0100
Quote CSC Analyst 9:46am, Sunday 7th June 2009
Dear Pierre,
This fault is currently undergoing testing. Further information will be appended to this ticket shortly.
Kind regards,
CSV Rep
[Sms Message: Your fault is currently being tested. Please ensure that you keep your equipment plugged in and powered on to give accurate test results. We will contact you with the outcome shortly.]
CSC Analyst 9:47am, Sunday 7th June 2009
Dear Pierre,
If you still think you have a connection problem we can raise this with BT for you. However, as we haven't found a problem with your phoneline or connection during our tests it is likely that BT will also find no fault. You might be charged £169.20 (including VAT) for this.
e-mails were slow
first
Message 3 of 3
(325 Views)
