Routing to Opendns
- Routing to Opendns
Re: Routing to Opendns
12-07-2013 11:42 AM
Ex-Broadband Service Manager
12-07-2013 11:47 AM
Quote The routing is decided by your ISP and we try to connect to the server closest to you, but if your ISP is routering through Frankfurt our system will see that and route you to the servers we have near that location.
It would be interesting to get level3's comments, then we can have 3 conflicting views
12-07-2013 11:48 AM
12-07-2013 11:54 AM
IMO level3 may be influencing this.
Do we assume Plusnet are not actively doing anything to get this resolved?
12-07-2013 12:10 PM
(out of my depth on routing though... so, I may be wrong, but checking)
12-07-2013 12:45 PM
Quote from: Kelly No idea, it's under there control. In theory you'd send the traffic to the closest server. That might not be the only reason though!
At least the trace route isn't showing hops to gchq.co.uk or prism.usa !
14-07-2013 6:39 PM
Having asked in the opendns forum one knowledge user had this to say:
Quote Yep, you got it! Level-3 is the culprit, they have suboptimal routing configured for those OpenDNS Anycast addresses. It seems OpenDNS is peering in London with network carrier tinet.net. Level-3 seems to attempt to keep the traffic in their own network instead of hand-over to Tinet, therefore routing on to the continent.
This sounds about right to me.
The following tracert confirms opendns peers with tinet.net.
Quote 1 1 ms 1 ms 1 ms 192.168.1.254
2 16 ms 18 ms 17 ms lo0-central10.ptn-ag03.plus.net [195.166.128.192]
3 15 ms 16 ms 17 ms link-b-central10.ptn-gw02.plus.net [212.159.2.138]
4 15 ms 15 ms 14 ms xe-8-2-0.ptw-cr02.plus.net [212.159.1.34]
5 16 ms 15 ms 18 ms ae2.ptw-cr01.plus.net [195.166.129.4]
6 16 ms 15 ms 17 ms ae1.pcl-cr01.plus.net [195.166.129.1]
7 16 ms 16 ms 17 ms xe-11-2-0.edge3.London2.Level3.net [212.187.201.213]
8 17 ms 18 ms 19 ms ae-0-11.edge4.London2.Level3.net [4.69.200.126]
9 17 ms 15 ms 18 ms ae-3-3.ebr1.London1.Level3.net [4.69.141.189]
10 22 ms 16 ms 15 ms ae-58-113.csw1.London1.Level3.net [4.69.153.122]
11 51 ms 15 ms 19 ms 4.69.166.5
12 156 ms 16 ms 16 ms IntelQ-Tinet-level3-2x10G.London.Level3.net [4.68.110.114]
13 17 ms 19 ms 15 ms xe-1-0-1.lon10.ip4.tinet.net [89.149.185.226]
14 145 ms 20 ms 19 ms rtr1.lon.opendns.com [208.69.34.1]
Can someone at plusnet please raise a ticket with level3 regarding routing to 208.67.222.222 and 208.67.220.220 (opendns) going to Amsterdam when it should be routed to London.
I don't see any other way this is going to be resolved.
14-07-2013 6:42 PM
14-07-2013 10:15 PM
I expect that Level 3 have 'costs' set up for their routes (actually, I don't expect, I know :P). Their route to Amsterdam will likely have a lower 'cost' associated with it than the route via tinet. (cost here isn't financial, it's merely a way of weighting routes.) Keeping the traffic within Level 3 has a lower 'cost' than offloading to another network (where there may actually be peering charges which are financial costs).
They were bringing some of their links from London to Frankfurt offline last weekend, due to having to replace a broken fibre offshore from Folkstone, and they were alternately routing to Amsterdam - this is likely why the destination flipped from Frankfurt to Amsterdam.
B.
14-07-2013 10:19 PM
Of course, at the end of the day you will probably find the response time from Amsterdam is similar to London anyway, although GeoDNs might be slightly affected, it will likely be trivial.
B.
15-07-2013 6:56 AM
Quote from: Barry Kelly - you may be able to favour an alternative route through LINX, rather than through your direct Level3 peer. Depends on what routing protocols you have, but you could set a higher routing cost for OpenDNS via Level3 to nudge the traffic out on alternate carriers.
Hi
Routing via public peering platforms is favored over our transit providers however we do not have a peering with OpenDNS over LINX. I'm sure the Ops team will look into this however it depends if OpenDNS will want to peer and what processes are in place on their side as to how long that takes. Trying to alter a global routing table on a per prefix basis becomes complicated at the size of the current table and often will come back to bite you when prefix sizes change as people run out of IPv4 addresses. In this case, as we take the route via transit we don't currently have anywhere else to move the traffic to (apart from another transit provider).
15-07-2013 10:16 AM
Quote from: paulmh5 Trying to alter a global routing table on a per prefix basis becomes complicated at the size of the current table and often will come back to bite
Sound a bit risky, to fix what may be a temporary problem at level3.
22-07-2013 11:17 AM
Tracing route to resolver1-fs.opendns.com [208.67.222.123]
over a maximum of 30 hops:
1 23 ms 99 ms 99 ms 192.168.0.254
2 22 ms 19 ms 18 ms lo0-central10.pcl-ag05.plus.net [195.166.128.186]
3 17 ms 18 ms 17 ms link7-central10.pcl-gw01.plus.net [84.93.249.140]
4 17 ms 17 ms 17 ms 208.core.access.plus.net [212.159.0.208]
5 17 ms 17 ms 17 ms xe-11-2-0.edge3.London2.Level3.net [212.187.201.213]
6 22 ms 18 ms 17 ms ae-0-11.edge4.London2.Level3.net [4.69.200.126]
7 25 ms 24 ms 25 ms ae-3-3.ebr1.London1.Level3.net [4.69.141.189]
8 24 ms 25 ms 25 ms vlan103.ebr2.London1.Level3.net [4.69.143.94]
9 25 ms 25 ms 25 ms ae-48-48.ebr2.Amsterdam1.Level3.net [4.69.143.81]
10 25 ms 24 ms 25 ms ae-59-224.csw2.Amsterdam1.Level3.net [4.69.153.214]
11 25 ms 25 ms 25 ms 4.69.139.172
12 25 ms 25 ms 25 ms OPEN-DNS-IN.edge6.Amsterdam1.Level3.net [212.72.47.62]
13 27 ms 27 ms 27 ms resolver1-fs.opendns.com [208.67.222.123]
Trace complete.
22-07-2013 12:38 PM
https://dns.norton.com/dnsweb/huConfigurePc.do
At least that's routing to a London server.
22-07-2013 3:27 PM
traceroute to 198.153.192.60 (198.153.192.60), 30 hops max, 60 byte packets
1 192.168.0.254 (192.168.0.254) 95.812 ms 95.775 ms 95.766 ms
2 lo0-central10.pcl-ag05.plus.net (195.166.128.186) 59.640 ms 61.886 ms 61.884 ms
3 link8-central10.pcl-gw02.plus.net (84.93.249.142) 21.747 ms 21.748 ms 21.749 ms
4 210.core.access.plus.net (212.159.0.210) 19.499 ms 21.731 ms 21.733 ms
5 ae2.pcl-cr01.plus.net (195.166.129.6) 32.989 ms 35.225 ms 35.224 ms
6 xe-11-2-0.edge3.London2.Level3.net (212.187.201.213) 21.719 ms 17.814 ms 17.834 ms
7 ae-0-11.edge4.London2.Level3.net (4.69.200.126) 20.051 ms 20.040 ms 20.029 ms
8 ae-3-3.ebr1.London1.Level3.net (4.69.141.189) 20.019 ms 20.009 ms 17.679 ms
9 ae-59-114.csw1.London1.Level3.net (4.69.153.126) 17.716 ms 19.937 ms 17.856 ms
10 ae-116-3502.edge3.London1.Level3.net (4.69.166.134) 49.468 ms 47.216 ms 47.205 ms
11 Vlan533.icore1.LDN-London.as6453.net (195.219.83.101) 28.936 ms * *
12 if-11-0-0-1254.mcore3.LDN-London.as6453.net (195.219.195.89) 17.851 ms 19.982 ms 19.979 ms
13 if-10-1-3.mse1.LRT-London.as6453.net (195.219.195.22) 19.964 ms 19.980 ms 19.977 ms
14 195.219.100.10 (195.219.100.10) 19.962 ms 18.235 ms 18.238 ms
15 198.153.192.60 (198.153.192.60) 18.347 ms 18.224 ms 18.212 ms
traceroute -I -A 198.153.192.60
1 192.168.0.254 (192.168.0.254) [AS28513] 100.111 ms 100.072 ms 97.821 ms
2 lo0-central10.pcl-ag05.plus.net (195.166.128.186) [AS6871] 24.057 ms 26.291 ms 28.432 ms
3 link8-central10.pcl-gw02.plus.net (84.93.249.142) [AS6871] 19.684 ms 21.908 ms 21.915 ms
4 210.core.access.plus.net (212.159.0.210) [AS6871] 21.901 ms 21.902 ms 21.895 ms
5 ae2.pcl-cr01.plus.net (195.166.129.6) [AS6871] 21.900 ms 21.891 ms 21.893 ms
6 xe-11-2-0.edge3.London2.Level3.net (212.187.201.213) [AS3356/AS9057] 21.890 ms 17.221 ms 17.941 ms
7 ae-0-11.edge4.London2.Level3.net (4.69.200.126) [AS3356] 20.176 ms 20.165 ms 20.157 ms
8 ae-3-3.ebr1.London1.Level3.net (4.69.141.189) [AS3356] 20.141 ms 20.135 ms 20.129 ms
9 ae-59-114.csw1.London1.Level3.net (4.69.153.126) [AS3356] 20.116 ms 20.110 ms 18.132 ms
10 ae-116-3502.edge3.London1.Level3.net (4.69.166.134) [AS3356] 18.095 ms 18.075 ms 17.545 ms
11 Vlan533.icore1.LDN-London.as6453.net (195.219.83.101) [AS6453] 30.734 ms * *
12 if-11-0-0-1254.mcore3.LDN-London.as6453.net(195.219.195.89) [AS6453] 18.659 ms 20.908 ms 20.897 ms
13 if-10-1-3.mse1.LRT-London.as6453.net (195.219.195.22) [AS6453] 20.876 ms 20.866 ms 20.858 ms
14 195.219.100.10 (195.219.100.10) [AS25337] 20.839 ms 18.759 ms 18.845 ms
15 198.153.192.60 (198.153.192.60) [AS33517] 18.347 ms 17.848 ms 18.322 ms
Many Thanks
