Routing issues?
Fixes: 9
Routing issues?
Is anyone on a ptw gateway experiencing issues reaching some sites?
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
Fixes: 9
Re: Routing issues?
Tracerts showing success from pcl and failure on ptw in #56930723
Fixes: 70
Re: Routing issues?
All ptw end-points jelv or just ptw-ag03? I've been unable to replicate your problem from ptw-ag01 although my traffic is going via a different core router.
Plusnet Products Team
Fixes: 9
Re: Routing issues?
I've been having terrible trouble with gateway hops - looking in the ppp log it's BT that's failing to respond.
I've only managed to hit ptw-ag03 and consistently had a failure on that gateway - all the other gateways have been pcl or ptn - mainly using my own login, but I've now hit pcl-ag03 using the products8 (E100 testing) login and the routing is OK.
Fixes: 70
Re: Routing issues?
I've a suspicion the products login will only let you on via a specific virtual router on ptw-ag03 jelv. Can't explain the problems you've had with your normal login mind you Undecided
