Routing issues?
- Re: Routing issues?
Routing issues?
25-06-2012 3:32 PM
Is anyone on a ptw gateway experiencing issues reaching some sites?
Message 1 of 5
(866 Views)
4 REPLIES 4
Re: Routing issues?
25-06-2012 3:57 PM
Tracerts showing success from pcl and failure on ptw in #56930723
Message 2 of 5
(392 Views)
Re: Routing issues?
25-06-2012 4:12 PM
All ptw end-points jelv or just ptw-ag03? I've been unable to replicate your problem from ptw-ag01 although my traffic is going via a different core router.
Message 3 of 5
(392 Views)
Re: Routing issues?
25-06-2012 4:52 PM
I've been having terrible trouble with gateway hops - looking in the ppp log it's BT that's failing to respond.
I've only managed to hit ptw-ag03 and consistently had a failure on that gateway - all the other gateways have been pcl or ptn - mainly using my own login, but I've now hit pcl-ag03 using the products8 (E100 testing) login and the routing is OK.
Message 4 of 5
(392 Views)
Re: Routing issues?
27-06-2012 5:26 PM
I've a suspicion the products login will only let you on via a specific virtual router on ptw-ag03 jelv. Can't explain the problems you've had with your normal login mind you
Message 5 of 5
(392 Views)
