Routing issue? Can't reach plus.net from my Plusnet FTTC connection
FIXED- Subscribe to RSS Feed
- Routing issue? Can't reach plus.net from my Plusne...
20-12-2022 10:32 AM
Hi folks,
Weird issue that I first noticed yesterday and it's still a problem today. I'm on Plusnet but can't reach the plus.net (or www.plus.net) website from my connection. This is from all browsers and machines at my house. If I VPN or proxy via somewhere else, I can access it (and it's how I'm writing this post now)
My current IP is 195.213.60.60
Unfortunately plus.net isn't pingable from anywhere which makes troubleshooting tricky.
Traceroute shows:
traceroute: Warning: www.plus.net has multiple addresses; using 212.159.9.2
traceroute to portal.plus.net (212.159.9.2), 64 hops max, 52 byte packets
1 * 192.168.1.254 (192.168.1.254) 0.711 ms *
2 * * *
3 * * *
4 132.hiper04.sheff.dial.plus.net.uk (195.166.143.132) 8.138 ms
128.hiper04.sheff.dial.plus.net.uk (195.166.143.128) 9.308 ms 9.047 ms
5 * 195.99.125.141 (195.99.125.141) 10.083 ms *
6 195.166.129.160 (195.166.129.160) 7.242 ms 8.436 ms *
7 * * *
8 * * *
9 * * *
10 * * *
... I can't really be bothered to log a ticket to troubleshoot this. I only noticed as I tried to access my bill yesterday. I can live without it as I have a workaround - but just thought the folks at Plusnet would like to know that something's not right.
Fixed! Go to the fix.
Re: Routing issue? Can't reach plus.net from my Plusnet FTTC connection
21-12-2022 12:41 PM - edited 21-12-2022 12:43 PM
- Plusnet servers do not respond to pings at all, so this is not a helpful approach to diagnostics
- What IP address does plus.net resolve to for you?
PS C:\Users\*****> nslookup Default Server: UnKnown Address: a.b.c.d (DNS server) > plus.net Server: UnKnown Address: a.b.c.d (DNS server) Non-authoritative answer: Name: plus.net Addresses: 212.159.8.2 212.159.9.2 > - What does pathping report for you?
PS C:\Users\*****> pathping plus.net Tracing route to plus.net [212.159.8.2] over a maximum of 30 hops: 0 ****.home [192.168.1.34] 1 192.168.1.254 2 195.166.130.255 3 84.93.253.123 4 84.93.224.48.plus.net [84.93.224.48] 5 84.93.232.57.plus.net [84.93.232.57] 6 * * * Computing statistics for 125 seconds... Source to Here This Node/Link Hop RTT Lost/Sent = Pct Lost/Sent = Pct Address 0 Lent.home [192.168.1.34] 0/ 100 = 0% | 1 4ms 0/ 100 = 0% 0/ 100 = 0% 192.168.1.254 0/ 100 = 0% | 2 --- 100/ 100 =100% 100/ 100 =100% 195.166.130.255 0/ 100 = 0% | 3 32ms 0/ 100 = 0% 0/ 100 = 0% 84.93.253.123 1/ 100 = 1% | 4 38ms 1/ 100 = 1% 0/ 100 = 0% 84.93.224.48.plus.net [84.93.224.48] 99/ 100 = 99% | 5 --- 100/ 100 =100% 0/ 100 = 0% 84.93.232.57.plus.net [84.93.232.57] Trace complete.
This IP address range has been allocated to Plusnet since Jan 2018 - see Webupdates — RIPE Network Coordination Centre
21-12-2022 1:27 PM
Hi @Townman
plus.net resolves as follows:
% nslookup plus.net
Server: 192.168.1.254
Address: 192.168.1.254#53
Address: 212.159.8.2
Address: 212.159.9.2
Pathping to both IPs:
C:\>pathping plus.net
Tracing route to plus.net [212.159.9.2]
0 media [192.168.1.4]
1 * * router [192.168.1.254]
2 172.16.14.203
3 * * *
Computing statistics for 50 seconds...
0/ 100 = 0% |
1 0ms 0/ 100 = 0% 0/ 100 = 0% router [192.168.1.254]
100/ 100 =100% |
2 --- 100/ 100 =100% 0/ 100 = 0% 172.16.14.203
Trace complete.
C:\>pathping 212.159.8.2
Tracing route to portal.plus.net [212.159.8.2]
1 router [192.168.1.254]
2 172.16.14.203
3 * * *
0/ 100 = 0% |
100/ 100 =100% |
Trace complete.
Thanks,
Rob
21-12-2022 1:40 PM - edited 21-12-2022 1:44 PM
To check on connection I'd suggest using telnet (if enabled) or Test-NetConnection in a Windows Power Shell, syntax would be
telnet www.plus.net 443
Test-NetConnection -ComputerName "www.plus.net" -Port 443
or
Test-NetConnection -ComputerName "www.plus.net" -Port 80
With both of the commands netstat can be used to check the connection(ESTABLISHED, TIME-WAIT, CLOSE-WAIT or SYN-SENT)
C:\>netstat -n | findstr 212.
TCP 192.168.10.100:50427 212.159.8.2:443 ESTABLISHED
Dan.
21-12-2022 1:45 PM
That pathping is dying as soon as it hits the Plusnet private network (gateway) at
172.16.14.203
What gateway does the router report on the basic status page?
Exactly what happens if you put https://plus.net into your browser's address bar?
Are you using add blockers / cookie crunchers...
21-12-2022 1:47 PM
Nice one - something new learnt today...
PS C:\Users\kevin> Test-NetConnection -ComputerName "www.plus.net" -Port 80
ComputerName : www.plus.net
RemoteAddress : 212.159.9.2
RemotePort : 80
InterfaceAlias : WiFi
SourceAddress : 192.168.1.34
TcpTestSucceeded : True
21-12-2022 4:25 PM
Telnet and Test-NetConnection both confirm there's no connection possible to plus.net / www.plus.net on port 80 or 443. This isn't a brower or OS issue - I've tested it across multiple platforms (MacOS, Windows, iPhone, etc.) and get the same results - a complete inability to reach plus.net (212.159.9.2 or 212.159.8.2)... Hence my original suggestion that there's a routing issue somewhere.
PS C:\Users\rob> Test-NetConnection -ComputerName "www.plus.net" -Port 80
WARNING: TCP connect to (212.159.9.2 : 80) failed
WARNING: TCP connect to (212.159.8.2 : 80) failed
WARNING: Ping to 212.159.9.2 failed with status: TimedOut
WARNING: Ping to 212.159.8.2 failed with status: TimedOut
RemotePort : 80
InterfaceAlias : Ethernet
SourceAddress : 192.168.1.4
PingSucceeded : False
PingReplyDetails (RTT) : 0 ms
TcpTestSucceeded : False
PS C:\Users\rob> Test-NetConnection -ComputerName "community.plus.net" -Port 443
ComputerName : community.plus.net
RemoteAddress : 18.244.114.49
RemotePort : 443
PS C:\Users\rob> Test-NetConnection -ComputerName "plus.net" -Port 443
WARNING: TCP connect to (212.159.9.2 : 443) failed
WARNING: TCP connect to (212.159.8.2 : 443) failed
ComputerName : plus.net
RemotePort : 443
Note that community.plus.net is fine - and it's on a completely different IP.
I wondered if there were any other addresses within the same subnet as www... that I could try. I discovered ftp.plus.net is a near neighbour and whilst it doesn't have a site configured on it, it is listening on port 80. But sure enough, I can't reach that either:
PS C:\Users\rob> Test-NetConnection -ComputerName "ftp.plus.net" -Port 80
WARNING: TCP connect to (212.159.8.91 : 80) failed
WARNING: TCP connect to (212.159.9.91 : 80) failed
WARNING: Ping to 212.159.8.91 failed with status: TimedOut
WARNING: Ping to 212.159.9.91 failed with status: TimedOut
ComputerName : ftp.plus.net
RemoteAddress : 212.159.8.91
RemotePort : 80
Any other sites you can suggest I try? Or can we nudge a Plusnet network engineer to check where the routing is stuffed?
Thanks.
21-12-2022 4:38 PM
@Bobsta - you've had the same IP address since Sunday morning. Try powering your router off for 10-15 mins or so and see if it's any better after powering it back up.
I'm wondering if a security application somewhere has blocked your IP.
22-12-2022 9:09 AM
Hi @bobpullen
Perhaps unsurprisingly, changing my IP (from a 195.213.xxx.xxx to a 31.111.xxx.xxx) has resolved the issue. I almost didn't want to take that step as it seems more of a workaround than a fix. Some other customer is likely to pick up my old IP at some point and may experience the same issue.
But thanks for indicating this could be due to security filtering. I've no idea what I might've done to anger the Plus.net systems - but either way, it's working onw.
Thanks,
Rob
22-12-2022 9:41 AM
It might not be you who has angered the Plus.net systems. It might have been a previous "owner" of that IP address that has been doing something dodgy and got the IP address in trouble. That's a big advantage of static IP Addresses. You know the history of them, at least since the point in time that you got it, which would likely be much longer ago than a dynamic address.
22-12-2022 11:17 AM
Indeed, but in terms of security filters, it is a bit draconian to inhibit a Plusnet IP address from accessing the membership centre over several days.
I would feel more reassured knowing what it was (is?) rather than what it is thought it might be. What happens to the next (hapless) user who gets that IP address assigned to them?
22-12-2022 11:34 AM
Yes, @Townman, totally with you. I was more trying to point out to @Bobsta that it might not be anything to do with them.
If that is the case, and all assumptions and guesses here are correct, then exactly what is being said about the next user is exactly what is seen with @Bobsta.
Hopefully @bobpullen can get to the bottom on it and get it corrected or block this particular IP address to be being assigned to customers in the future (or at least until the issue(s) with it are cleared).
