Routertstats with BT2701HGVC Router
- Routertstats with BT2701HGVC Router
28-01-2015 4:43 PM
I seem unable to get routerstats to work with this 2 Wire BT router any ideas or is it not possible ?
Message 1 of 4
(778 Views)
3 REPLIES 3
Re: Routertstats with BT2701HGVC Router
30-01-2015 3:23 PM
Some years ago I successfully got routerstats working with a BT2700HGV. Not sure that helps much as I would expect the routers firmware is now different and routerstats has been upgraded a number of time since.
IIRC, there was no telnet login available in that router I had to configure routerstats to login to the routers web interface. From there I configured routerstats to load the routers web page with the stats and indicated the position of the specific stat i wished to record. The router had two different web pages showing stats, IIRC one worked better than the other.
Message 2 of 4
(484 Views)
30-01-2015 5:29 PM
Thank you I don't think I am up to that
Message 3 of 4
(484 Views)
30-01-2015 6:12 PM
The following link say routerstats-lite (the plug n play version) works with 2wire 2701HG-D.
http://www.vwlowen.co.uk/internet/files.htm
Did you try the "Lite" version?
Message 4 of 4
(484 Views)
