Routerstats Lite/Full
jem16
Will the Technicolor TG582n work with Routerstats Lite or Full?
Basically I just switched over from Sky and was using the Lite version as I couldn't get the full version to work with the Sky Router. There was no entry to select the Technicolor but there was a Thomson 582n so chose that. IP address was fine for that selection and I put the login details in as Admin and the number beginning with CP.
However it doesn't seem to be working with Lite so far. I have previously used the full version with O2 so should be able to get it working.
Can anyone help please?
Fixes: 9
Re: Routerstats Lite/Full
The full version is absolutely fine with the TG582.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
southerner
I have Routerstats full working with my TG582/Plusnet Technicolor router. Was easy to setup. On the config tab I just selected TG582n for the router type and supplied my admin password. It prepopulated eveything else for me once I had selected the router. Cool peice of software.
jem16
Thanks to both of you. I've downloaded the full version and will set it up.
Meanwhile figured out what was wrong with the Lite version - Admin had a capital A instead of a small a. Got that working now.
Fixes: 21
Glad you got that sorted, I was about to post that Lite works fine too.
jem16
Last time I used RouterStats full I was able to save a log with various pieces of info on it. I seem to only be getting the date, time and uptime. Previously I'm sure I also had the RX noise level but I can't seem to get it. Am I missing an obvious setting somewhere?
Fixes: 21
Yep probably. On the Configuration/Log tab you've got "Enable log" ticked ? and on each of the graphs whose data you want logged,right click and select "Include in Log". HTH.
jem16
Yes I've enable the log and the graphs have got a tick next to them for Include in log.
Unfortunately they are not being included.
Fixes: 58
check if you have Log Rx noise margin changes ticked - as it shouldn't be
however that doesn't explain why you aren't getting the data as follows which should be the default setting
Sun 27 May 2012  17:45:17 Rx-Noise=5.5 Tx-Noise=23.0 Rx-Sync=4832 Tx-Sync=448
with CRC errors set up as user defined I have
Sat 15 Nov 2014  11:45:59 Rx-Noise=5.7 Tx-Noise=9.4 Rx-Sync=3894 Tx-Sync=888 Rx-CRC=10662.0 Tx-CRC=632.0
jem16
RX Noise margin changes is not ticked.
Fixes: 21
On the Schedule Tab, Log every Sample ? Don't need Rx Noise Margin changes +/- x% ticked unless you particularly want it.
Fixes: 58
Just had a play
Try the following
Go to the relevant graph such as noise margin
Then click on Copy Graphs to log
Fixes: 21
Any luck so far?
jem16
Yes just tried that and it certainly copies it over to the log. It doesn't seem to log it automatically though and I'm pretty sure a previous version (or at least my O2 router) used to do it automatically.
I'm trying to see if there's any reason behind some sudden dips in Rx-Noise. Sometimes it's registering around 11.3 and then it drops suddenly to around 6.
Fixes: 58
If you open the ini file using notepad does this bit look the same as yours
LogAtSample=0
LogAtEvery=1
LogAtAlarm=0
LogState=0
LogUptime=0
LogAtInterval=10
