Routers and Stats
sjrinfroyle
Routers and Stats
Does anybody know what chipset these routers use? What are they like in terms of sync speed?
Fixes: 62
Re: Thomson TG582N
sjrinfroyle
Re: Thomson TG582N
How does this router sync?
jojopillo
Re: Thomson TG582N
Not sure I understand the question there.
Jojo Smiley
dick:quote
sjrinfroyle
Re: Thomson TG582N
Hi Joanne, what is the fastest syncing router that you have tried?
sjrinfroyle
My Stats
jojopillo
Re: Thomson TG582N
A Thomson TG585v7. Don't forget it's a bit of a lottery really, as it depends on line length/quality and the compatibility with the exchange equipment. Smiley
sjrinfroyle
Re: Thomson TG582N
Are these still available from you (Plusnet)?
jojopillo
Re: Thomson TG582N
No, it's just the v8 we supply now.
Jojo Smiley
sjrinfroyle
Re: Thomson TG582N
That's a pity. I will look around the web...
jojopillo
Re: Thomson TG582N
I imagine you should get a 2nd hand one somewhere. Don't forget though, just because it was good for me doesn't necessarily mean it will for you.
sjrinfroyle
Re: Thomson TG582N
Anything is worth trying! Would you mind posting a connection graph for me?
I am very grateful for all your help.
Fixes: 68
Re: My Stats
Here's your logs for the last week. Is there any reason you're asking for these such as a suspected issue?
<img src="http://ccgi.psmith12.plus.com/visradius/generated/image13202502973349.png" />
 Adam Walker
sjrinfroyle
Re: My Stats
I was just seeing how the line has been since the fault was fixed. It is looking a bit better.
jojopillo
Re: Thomson TG582N
Quote from: sjrinfroyle
Adam's already done that here.
Jojo Smiley
