RouterStats Twin Peaks
Fixes: 51
Can anyone hazard a guess as to what this might be about (see attached screen-shot below).
Sync speed is a flat line at 8064Kbps.
Customer and Forum Moderator.
x47c
Re: RouterStats Twin Peaks
Wild guess:
?Local electric power cut on one of the 3 phases? - not the one you are connected to obviously
So all the local electric and ADSL related phone line noise from those homes on the phase which failed disapears and the result is a short duration noise margin rise on those lines which are still working.
Fixes: 51
I had another one later...
Tue 17 Apr 2012  13:56:44 Rx-Noise=6.1 Tx-Noise=24.0 Rx-Sync=8064 Tx-Sync=448
Tue 17 Apr 2012  13:57:14 Rx-Noise=9.3 Tx-Noise=24.0 Rx-Sync=8064 Tx-Sync=448
Tue 17 Apr 2012  13:57:44 Rx-Noise=9.3 Tx-Noise=24.0 Rx-Sync=8064 Tx-Sync=448
Tue 17 Apr 2012  13:58:14 Rx-Noise=9.4 Tx-Noise=24.0 Rx-Sync=8064 Tx-Sync=448
Tue 17 Apr 2012  13:58:44 Rx-Noise=9.3 Tx-Noise=24.0 Rx-Sync=8064 Tx-Sync=448
Tue 17 Apr 2012  13:59:14 Rx-Noise=9.3 Tx-Noise=24.0 Rx-Sync=8064 Tx-Sync=448
Tue 17 Apr 2012  13:59:44 Rx-Noise=9.3 Tx-Noise=24.0 Rx-Sync=8064 Tx-Sync=448
Tue 17 Apr 2012  14:00:14 Rx-Noise=9.3 Tx-Noise=24.0 Rx-Sync=8064 Tx-Sync=448
Tue 17 Apr 2012  14:00:44 Rx-Noise=6.2 Tx-Noise=24.0 Rx-Sync=8064 Tx-Sync=448
Very strange.
Maybe BTOR are messing about in my exchange with fibre ongoing in there and ADSL2+ on the horizon.
@x47c That's a possibility but I haven't been monitoring phase status today Wink Smiley and nothing on here http://www.northernpowergrid.com/page/serviceinterruptions.cfm
