RouterStats Lite (Belkin F5D7633-4)
- RouterStats Lite (Belkin F5D7633-4)
02-07-2008 9:52 AM
Good morning
I have been using RouterStatsLite (v2.7b) to monitor my Voyager router connection as I am still having connection/speed problems (BT are still working on my line).
I would prefer to use my Belkin F5D7633-4 router but I can't find the URL to access the stats page - can anyone let me know what it is please?
The default for the Belkin F5D8630 is http://192.168.2.1/statsadsl.html but that doesn't seem to work on my router.
Message 1 of 2
(1,416 Views)
1 REPLY 1
Re: RouterStats Lite (Belkin F5D7633-4)
02-07-2008 11:05 PM
The (summary) router stats are shown on the status page which is I believe what 192.168.1.1 comes up with. You can also activate SNMP if you are using an snmp server to capture real time stats by running: http://192.168.1.1/snmpconfig.html
To get the stats through telnet login to the above IP address and then run: [tt]adsl info --stats[/tt]
Hope this helps.
Hope this helps.
Message 2 of 2
(340 Views)
