Router
Kaderlud
Router
Cannot access my router with admin and cp adress no information on website
RPMozley
Fixes: 5
Re: Router
The password is case sensitive, so you need to use CAPITALS with the PlusNet supplied router.
That's RPM to you!!
Kaderlud
Re: Router
Thank you will try simple thing could be in instructions surely
RPMozley
Fixes: 5
Re: Router
Well there is a page somewhere in the support section. It's not the easiest thing to navigate yourself around, I grant you, but the info is there.
That's RPM to you!!
Kaderlud
Re: Router
Tried upper case still cant
RPMozley
Fixes: 5
Re: Router
Is this for wireless access or to log in to the router's setup pages?
That's RPM to you!!
Kaderlud
Re: Router
To log into access pages
RPMozley
Fixes: 5
Re: Router
So you've tried putting in admin and CP**** but that didn't work. Hmm... Are you on ADSL or Fibre?
That's RPM to you!!
Kaderlud
Re: Router
Thanks for your time I am not a technophobe I am not on fibre I am trying to get my CCTV system on line need to adress port
RPMozley
Fixes: 5
Re: Router
Well I was asking because on ADSL switching off and on again (to fix the log in issue) can sometimes be problematic and at this time of night not really recommended for getting a good speed. If it can wait till the daytime it might be best to do that then.
That's RPM to you!!
Fixes: 5
Re: Router
Hi, this page should help:
http://www.plus.net/support/broadband/hardware/technicolor-582n-faqs.shtml#userPass
If it's not those details, did you change them in the menu before?  A factory reset (detailed at the bottom of that page) will reset the passwords back if you need to.
Kelly Dorset
Broadband Service Manager
