Router
- Router
Router
27-08-2013 5:44 PM
I've just set up an account for my daughter with Plusnet.
Can anyone tell me what router is currently being supplied and possibly point me towards setting up instructions. I appreciate these will accompany the router - I merely want to get an idea before the router arrives - which will be after her line is reconnected...
Message 1 of 6
(1,151 Views)
5 REPLIES 5
Re: Router
27-08-2013 6:52 PM
The Technicolor 582n router is being supplied. The setup guide can be found here:-
http://www.plus.net/support/broadband/hardware/
Message 2 of 6
(426 Views)
Re: Router
27-08-2013 8:27 PM
Thanks acr - I can do some homework now !
J
J
Message 3 of 6
(426 Views)
Re: Router
30-08-2013 7:40 PM
Bear in mind they do not have a good Wi-Fi signal. A trip to the PC store may be the case for a better router, my mum picked a one off for £30 which has an excellent signal in her house (4 bed) It was a Netgear Brand from PC World HERE
Ex Plusnet Fibre customer. Sky Ultrafast (G.Fast) Customer using a Sky Hub 4.2. If you wish to say thanks, please click the thumbs up
Message 4 of 6
(426 Views)
Re: Router
17-09-2013 8:04 PM
NorthEasterner - thanks for that.
The new Router seems to be working ok but it's only a small bungalow so maybe that helps!
Message 5 of 6
(426 Views)
Re: Router
17-09-2013 8:27 PM
192.168.1.254 in browser to access.
username: admin
password is router's serial number starting CPxxxxxxxxxxxx
username: admin
Message 6 of 6
(426 Views)
