Router with WPA2 Enterprise
- Re: Router with WPA2 Enterprise
29-09-2013 9:45 AM
Looking for a router with WPA2 enterprise and cheapest as possible looking to spend £50 tops.
Any suggestions greatly appreciated.
Jamie
Jamie
Ex Plusnet Fibre customer. Sky Ultrafast (G.Fast) Customer using a Sky Hub 4.2. If you wish to say thanks, please click the thumbs up
Message 1 of 8
(2,673 Views)
7 REPLIES 7
29-09-2013 10:21 AM
Hey.
Netgear RangeMax WNR1000 Has WPA2 Enterprise. Very reliable, costs around £45.
Having said that, our router supports WPA2 (Technicolor TG582n) However I don't actually know the difference between this and WPA2 Enterprise?
Message 2 of 8
(1,457 Views)
29-09-2013 10:45 AM
Quote WPA2 Personal is the main WiFi security method and this is what most home and small business users use. It uses a single password. Most WiFi networks use this method.
WPA2 Enterprise is also called 802.1x and is the enterprise method. This method shouldn't be used by home users as it requires a RADIUS authentication server and needs a username and password. It supports multiple accounts for each user.
copied and pasted from a reply someone wrote on another forum
Message 3 of 8
(1,457 Views)
29-09-2013 10:57 AM
This may help the confusion.
WPA2 Personal is the main WiFi security method and this is what most home and small business users use. It uses a single password. Most WiFi networks use this method.WPA2 Enterprise is also called 802.1x and is the enterprise method. This method shouldn't be used by home users as it requires a RADIUS authentication server and needs a username and password. It supports multiple accounts for each user.
http://freeradius.org/
http://www.ciscopress.com/articles/article.asp?p=1576225&seqNum=3
Message 4 of 8
(1,457 Views)
29-09-2013 11:01 AM
Reason is because we have client files on our system and so it needs to be only accessed by authorised people.
Is WPA2 Enterprise able to use without a server? So I set up user names and passwords on the router GUI? I currently have a Netgear WNR1000 supplied by PN.
I will then have two wifi systems running one for authorised users and other for other users
Message 5 of 8
(1,457 Views)
29-09-2013 12:15 PM
Possible guide here...
http://www.privacywonk.net/2010/10/security-how-to-wpa2-enterprise-on-your-home-network.php
Sounds like you'd be better off securing the files on the server instead though...
Message 6 of 8
(1,457 Views)
29-09-2013 5:59 PM
Quote from: NorthEasterner Is WPA2 Enterprise able to use without a server? So I set up user names and passwords on the router GUI? I currently have a Netgear WNR1000 supplied by PN.
No, it cannot be used without a server.
I think WPA2 Personal would suffice for what you're trying to do. WPA2 Enterprise is really designed for an enterprise-level environment where you have users logging in with their network credentials.
Message 7 of 8
(1,457 Views)
29-09-2013 6:00 PM
Quote from: pwatson Sounds like you'd be better off securing the files on the server instead though...
+1
Message 8 of 8
(1,457 Views)
