Router with Voip ports recomendatons
- Router with Voip ports recomendatons
24-01-2013 8:15 PM
over the last year or so the 780wl started randomly re-booting ( not very oftne but a pian in the backside non the less)
Thne my ADSL went down, which resulted in a BTR open reach bod having a poke around, after which everythuing started to work again.
He did however sugest that i update my modem/router, and upon furhter talks with plusnet they sent me a TG582n which so far hasnt self re-booted.
the only downside is that i miss my Voip phone
any recomendations? or should i just get a cheap linksys pap2 from e-bay ( £13-£40 )?
Re: Router with Voip ports recomendatons
24-01-2013 8:25 PM
Siemens do a range of DECT IP/Analogue base stations and associated handsets
Example: http://www.broadbandbuyer.co.uk/Shop/ShopDetail.asp?ProductID=12485&utm_source=google&utm_medium=sho...
24-01-2013 8:29 PM
25-01-2013 6:17 AM
25-01-2013 6:51 AM
It seems that the only other manufacturer including VOIP/SIP ports into routers is Draytek, but their routers are also quite expensive.
dick:quote
25-01-2013 7:42 AM
25-01-2013 9:56 AM
It will connect directly to the pn service but you have to flash it to get additional sip providers on it, simple takes about 10 min.
Still using mine via bridge mode to my fibre service.
(I also had a 780wl great router.)
28-01-2013 7:47 PM
29-01-2013 10:38 PM
