Router with Voip ports recomendatons
- Re: Router with Voip ports recomendatons
24-01-2013 8:15 PM
For many years I have been using a Sppedtouch ST780wl with two voip port, combined with plusnets voip service ( and sometimes sipgate)
over the last year or so the 780wl started randomly re-booting ( not very oftne but a pian in the backside non the less)
Thne my ADSL went down, which resulted in a BTR open reach bod having a poke around, after which everythuing started to work again.
He did however sugest that i update my modem/router, and upon furhter talks with plusnet they sent me a TG582n which so far hasnt self re-booted.
the only downside is that i miss my Voip phone
any recomendations? or should i just get a cheap linksys pap2 from e-bay ( £13-£40 )?
Message 1 of 9
(2,244 Views)
8 REPLIES 8
24-01-2013 8:25 PM
Personally I would (well actually, did) go for an IP phone instead - Saves all the 4 wire<>2 wire conversion and resultant echo issues.
Siemens do a range of DECT IP/Analogue base stations and associated handsets
Example: http://www.broadbandbuyer.co.uk/Shop/ShopDetail.asp?ProductID=12485&utm_source=google&utm_medium=sho...
Message 2 of 9
(997 Views)
24-01-2013 8:29 PM
Thnaks, i thought about the ip phone route, but i would prefer an all in one solution 9 if possible ) , ive already got the ( standard ) wired phones iin place+ the cabling and Dect cordless phones have always been probelmatic for me.
Message 3 of 9
(997 Views)
25-01-2013 6:17 AM
If your budget is good go for a Fritz box
Message 4 of 9
(997 Views)
25-01-2013 6:51 AM
If you win the lottery, go for a Fritzbox...
It seems that the only other manufacturer including VOIP/SIP ports into routers is Draytek, but their routers are also quite expensive.
dick:quote
dick:quote
Message 5 of 9
(997 Views)
25-01-2013 7:42 AM
Zoom also do one http://www.zoomtel.com/products/voip_products.html#5695
Message 6 of 9
(997 Views)
25-01-2013 9:56 AM
If you are on ADSL then get a BT HH2, I got a new one of freecycle but they are on ebay/boot sales etc..
It will connect directly to the pn service but you have to flash it to get additional sip providers on it, simple takes about 10 min.
Still using mine via bridge mode to my fibre service.
(I also had a 780wl great router.)
Message 7 of 9
(997 Views)
28-01-2013 7:47 PM
Thnbaks for the replys so far, any opinions on the TP-Link TD-VG3631 here http://www.broadbandbuyer.co.uk/Shop/ShopDetail.asp?ProductID=13594 ; ?
Message 8 of 9
(997 Views)
29-01-2013 10:38 PM
If i was to buy the above, would it be future proof? hopefuly it would last a few years
Message 9 of 9
(997 Views)
