Router sync speed is 40 down, 2 up
matthews
Re: Router sync speed is 40 down, 2 up
I think that's hours rather than minutes, but it does seem to reset itself quite frequently (and it's not the router being power-cycled).
I'm hoping someone from Plusnet can pick it up from this as I'm not visiting again for a few weeks, but at some point I'll try and get me added as an authorised person. I had a really good experience with the SMS based fault reporter for my own line, but that's already tied to my account so I can't use that for them on their behalf. Not sure there is a mobile registered on their account yet.
Thanks community for your assistance 😊
Fixes: 378
@matthews Unless @willcutforth spots this, I doubt you will be lucky with the Help Team, sadly.
Fixes: 145
Yes I just noticed my mistake, not had my morning cup of tea!
You can use https://faults.plus.net
You need the members centre username and password for this. (broadband username without the @plus.net, same password)
SammyM
Fixes: 101
Hiya @matthews
I'm sorry you are having issues with your line, can you pop me your username over in a DM and we will take a look into this for you.
 Sammy M - Sheffield Team
