Router stopping PS4 conecting
- Router stopping PS4 conecting
11-01-2014 1:26 PM
As title says, i have 2 PS4 and one connects no problem using wifi, and other worked up untill Tuesday . Now it only gets an IP address, but then fails with internet connection when i try connect. In my router it says in alerts:
FIREWALL icmp check (1 of 1): Protocol: ICMP Src ip: 5.135.14.249 Dst ip: 87.113.16.19 Type: Destination Unreachable Code: Port Unreacheable
FIREWALL replay check (1 of 23): Protocol: ICMP Src ip: 81.155.246.251 Dst ip: 87.113.16.19 Type: Destination Unreachable Code: Host Unreacheable
FIREWALL replay check (1 of 53): Protocol: ICMP Src ip: 91.138.75.147 Dst ip: 87.113.16.19 Type: Destination Unreachable Code: Port Unreacheable
every time i try connect. I have initialised the PS4 to factory defaults, reset my router using the small pin hole in back, making that factory default.
Before this i tried portforwarding PS4 ports using game and application settings.
Im on plusnet fibre, using Technicolor 582n. I can connect with whatever device i want except the PS4, even when its only device connected. Anyone help, ive got one upset little lad!
Message 1 of 5
(2,515 Views)
4 REPLIES 4
Re: Router stopping PS4 conecting
11-01-2014 3:10 PM
Do you have uPNP enabled?
Try enabling Pings on your WAN Interface (I think is under Firewall settings) to see if that also helps.
Message 2 of 5
(918 Views)
12-01-2014 1:03 PM
Hi andy, i've tried enabling pings and uPNP was enabled but i get the same problem
this was from trying with pings enabled
FIREWALL replay check (1 of 5): Protocol: ICMP Src ip: 82.5.233.240 Dst ip: 87.113.16.19 Type: Destination Unreachable Code: Host Unreacheable
Message 3 of 5
(918 Views)
12-01-2014 1:26 PM
Thanks for your help, i worked it out. Even after factory resets on both ps4 and router, for some reason it was trying to give it an ip 87.113.16.19. I clicked on "Assign the public IP address of a connection to a device" and unassigned it, happy days!
Message 4 of 5
(918 Views)
12-01-2014 1:59 PM
Glad you got it fixed. The Technicolor/Thomson routers are not good for gaming console support.
Message 5 of 5
(918 Views)
