Router return bag?
- Re: Router return bag?
Router return bag?
07-01-2014 10:50 AM
Please could someone explain the unexpected appearance of a router return bag through my letterbox this morning? I also notice there is a closed ticket on my account (No 181646808) which says 'RMA received'. Does this mean I am getting a replacement router - and if I am, please could you let me know when I am likely to receive it?
Alan
07-01-2014 11:07 AM
I'm just looking into this. Unfortunately nothing has been documented on the account about an RMA but I'm wondering if this was done in relation to when you called us on the 4th as per ticket 79395455.
I'm trying to contact the agent now, if a router does turn up (if so I'd imagine it would tomorrow) please just pop it in the bag and post that back to us.
07-01-2014 12:10 PM
Thanks for the reply - but now I am even more confused... You say nothing has been documented on my account about an RMA, but I definitely have a service notice which was put on my account at 00:52 today which says 'RMA received' - I have tried to attach a screen shot, which I hope works!
Yes, I was rather hoping it was related to ticket 79395455 - which relates to a call where I had asked for my router to be replaced foc. Are you really saying that if I do now receive a replacement I have to return it???
07-01-2014 12:26 PM
Quote Are you really saying that if I do now receive a replacement I have to return it???
Keep it if you need it, I wasn't sure if one was actually needed.
07-01-2014 12:58 PM
Sadly I am still no clearer about what is going on and whether I am getting the replacement router I requested... I assume you weren't able to contact the agent who put ticket 79395455 on my account after I spoke to him on Sunday? If you do manage to find out any more I would be grateful if you could let me know.
07-01-2014 1:05 PM
I can see mentioned on that ticket one of the lights was red but the router is otherwise working fine, is that the case?
07-01-2014 1:30 PM
I have had the router since September, and all was fine until the red light problem emerged in December. I raised the issue in another post, and one of your colleagues suggested it might be caused by errors on my connection ( http://community.plus.net/forum/index.php/topic,121688.msg1054845.html#msg1054845 ). I have a funny feeling the problem might only have arisen since my upload was uncapped, which could support that theory as I have seen an increase in errors upstream since then - but I'm not sure... As it is unclear whether this is being caused by the dreaded red-light syndrome or errors, I would like the router replaced to see if that solves the problem - I am reluctant to go for having interleaving turned on or re-capping my upload speed if it is just the router playing silly devils...
I'm not sure if that's something you can help facilitate? I could also mention that my router seems to be one of the noisy whistling ones - but to be honest, even though it's in my bedroom it doesn't cause me any problems as a wardrobe between the router and the bed seems to block the whistle. Either that or my hearing is not as good as it used to be!
08-01-2014 10:32 AM
Any news on this? I had another disconnection yesterday afternoon and it reconnected with a higher sn margin on the upstream, resulting in slower upload speeds... Router lights are back to all green, but for how long I wouldn't like to say...
Cheers
Alan
10-01-2014 12:37 PM
I'm not convinced the disconnections may be down to the router, however I've dispatched a replacement for you so we'll have to see how things go after that. Hopefully that will fix the issue but if not I'd advise raising a fault at that point: http://faults.plus.net
10-01-2014 12:52 PM
