Router reset button
- Router reset button
Router reset button
28-04-2014 8:36 PM
I have just replaced a BT Home Hub 5 modem/router with a better Asus router. I shall now sell the Home Hub but I forgot to remove the SSID and passwords. There is a reset button on the router for taking it back to factory settings. My question is - if I power up the Home Hub without connecting it to my network, will the reset button revert the router back to the original SSID and passwords that are printed on the router? I need to ensure whoever buys it can login to it.
I don't want to connect it to my computer now in case it messes with my network.
Message 1 of 7
(3,457 Views)
6 REPLIES 6
Re: Router reset button
28-04-2014 10:37 PM
The reset button will work whether on a network or not.
The principle thing is that it's held in until 'something' happens.
The lights will change, flash, or go out - something will happen - you'll know it when you see it.
In my experience it always takes longer than expected.
Murphy was an optimist
Zen FTTC 40/10 + Digital Voice FRITZ!Box 7530
BT technician (Retired)
Message 2 of 7
(2,779 Views)
28-04-2014 11:52 PM
Thanks for that but what I need to know is will the router revert back to the original SSID and password printed on the case.
Message 3 of 7
(2,779 Views)
29-04-2014 9:23 AM
You can probably check - power it up and see if it's back to the original SSID (is printed on the back?).
Message 4 of 7
(2,779 Views)
29-04-2014 12:21 PM
According to BT,
Instructions
Quote Resetting a BT Home Hub to factory settings takes the Hub right back to how it was when you first got it. It will overwrite any changes you might have made since.
Instructions
Message 5 of 7
(2,779 Views)
29-04-2014 7:48 PM
Thanks for the replies. I will do the reset but I can't see if it has reverted to the original SSID without connecting to the network, which is what I am trying to avoid. I shall reset and hope it reverts to what is printed.
Message 6 of 7
(2,779 Views)
29-04-2014 7:50 PM
when returning to factory settings, all settings / SSID's will have to be reset
Message 7 of 7
(2,779 Views)
