Router recommendations-Plusnet's don't work with fibre, had 3 of them!
caqual
Please can someone recommend a decent router which can cope with fibre broadband with 4 wireless laptops, 4 wireless phones, a smart TV and a printer and main computer as the Plusnet one I had installed 3 weeks ago has been rubbish and either constantly disconnects or drops, (even the main computer) and it is doing my head in!Huh?
Since I've upgraded to fibre, had nothing but problems and 3 different routers!! Many thanks.
Re: Router recommendations-Plusnet's don't work with fibre, had 3 of them!
Hi caqual,
Is is speeds that seem to be the issue or connectivity? If it's wireless your having problems with have you itried changing your wireless channel to see if that helps?
EDIT - I can see that our faults team have been through this with you.
My Asus RT-N56U is brilliant & will handle your traffic standing on its head. I bought mine from Amazon for £78.00, now £76.00. It's also available on Ebay for a few £s less.
