Router recomendations
- Router recomendations
27-05-2014 9:53 PM
I am about to ditch my second TP-Link router as the 2.4Ghz keeps disappearing.
Can anyone suggest a replacement router.
I am looking for the following specs.
2.4Ghz
5 Ghz.
2 usb ports.
ac if possible.
Sadly money is an object 🙂
Approx £80 ish.
podman
2.4Ghz
5 Ghz.
2 usb ports.
ac if possible.
Approx £80 ish.
podman
Message 1 of 6
(912 Views)
5 REPLIES 5
Re: Router recomendations
28-05-2014 9:01 AM
I'd recommend the BT Home Hub 5 EXCEPT its only got 1 USB port
got mine from a well known auction site for £55
Message 2 of 6
(486 Views)
28-05-2014 9:25 AM
I think getting the 2 USB ports will be an issue
Message 3 of 6
(486 Views)
28-05-2014 10:42 AM
You could probably connect a USB hub to it.
Message 4 of 6
(486 Views)
29-05-2014 7:11 PM
I opted for the Asus n56u in the end. Great reviews and quite good looking router.
Going home to set it up.
Message 5 of 6
(486 Views)
29-05-2014 8:28 PM
Quote the Asus n56u in the end.
I've been using mine for 18 months. It's absolutely brilliant, incredibly fast & totally reliable. Asus are obviously happy that they have it sorted because the frequency of firmware updates has decreased enormously.
Message 6 of 6
(486 Views)
