Router random resets and DLM
- Router random resets and DLM
Re: Router random resets and DLM
17-12-2013 9:53 AM
19-12-2013 2:32 PM
20-12-2013 11:20 AM
20-12-2013 12:30 PM
Quote from: davvy76 Again, no change. What is supposed to happen next? BT have confirmed there's no fault on my line and it syncs at 9.4.
Where have you seen it syncing at 9.4? I'm seeing you syncing at 5399?
Ex-Broadband Service Manager
20-12-2013 1:54 PM
20-12-2013 2:01 PM
20-12-2013 3:22 PM
If it's not then I can retry the test when it is plugged in
Plusnet Technology
20-12-2013 3:55 PM
20-12-2013 4:07 PM
Full size http://i.imgur.com/Y4CxT71.jpg
I'll leave it connected and continue to borrow my neighbours wi fi in the mean time.
20-12-2013 4:49 PM
20-12-2013 4:52 PM
Speed: 1039 10551
157 errored second since it resync'd which is a lot.
I'm wondering if the chipset in the routers are behaving differently based on the line conditions and the Sky router's is being less conservative and allowing the router to sync at a higher rate, but a rate that sees errors.
That was the interesting thing I wanted to see between the 2 routers. We do see differences in sync rates between routers but more often on long lines as some chipsets are better than others on long lines. This isn't that long a line and while 10Mbps for the line length is doing extremely well, 5Mbps is below what you'd expect for the length of line and attenuation.
Did you say you had another router or was I misreading? What sort is it if you do?
You can switch back to the other router by the way.
Plusnet Technology
20-12-2013 6:17 PM
21-12-2013 10:14 AM
A nice improvement, however after rebooting it today the sync has dropped again to 5300 odd. I really don't understand what's happening considering the line was good for 38mb fttc in November of this year.
22-12-2013 12:39 PM
22-12-2013 1:07 PM
