Router random resets and DLM
- Router random resets and DLM
Re: Router random resets and DLM
01-12-2013 10:59 AM
01-12-2013 5:01 PM
If the DLM does react adversely to the disconnections the Digital Care Team staff on the forums will probably be happy to do a training reset if you can demonstrate connection stability for a suitable period.
01-12-2013 11:19 PM
http://community.plus.net/forum/index.php/topic,120359.msg1043257.html#msg1043257
03-12-2013 4:29 PM
09-12-2013 2:23 PM
09-12-2013 2:29 PM
11-12-2013 4:04 PM
As per usual the downstream attenuation is around 42db just like in my previous posts which should be good for approx 8500kbps. I've done the 17070 quiet line test and there's no discernible noise. Confusing!
11-12-2013 4:25 PM
13-12-2013 12:34 PM
13-12-2013 12:39 PM
Quote from: davvy76 Argh! New router, higher sync, lower throughput, what on earth is going off? Is there a cooling off period for this service?
13-12-2013 12:43 PM
Ex-Broadband Service Manager
13-12-2013 2:15 PM
I do indeed have an xbox one, why do you ask? Its set to power saving though so it doesn't download updates unless I physically switch it on, just in case you were thinking it was background downloading whilst I was doing speedtests. It's also hard wired into a 5 port network switch which in turn gets the internet via cat5e from the plusnet router.
13-12-2013 4:37 PM
15-12-2013 2:33 PM
16-12-2013 9:41 AM
