Router "lost" its config?
- Router "lost" its config?
05-09-2010 2:48 PM
Well, sorta..
I have a speedtouch 585v7 (plusnet supplied). I had been away dahn sarf for a few days so unplugged my router. When I returned home I couldn't connect wirelessly. So I plugged in ethernet, couldnt login to router - seems strange. Tried default password and it worked. Same with wireless - it had reverted back to WPA1 and the key was the same as that on the bottom of the router.
I cant put this down to anything and wouldnt have thought leaving it off a few days would cause it to loose all its config (it's all stored in solid state right!?) Unless plusnet can/have upgraded the firmware on these things remotely??
Very strange
Very strange
Message 1 of 2
(543 Views)
1 REPLY 1
Re: Router "lost" its config?
05-09-2010 9:26 PM
Hi badwolf,
That shouldn't happen, but as with all electrical/computer equipment they do tend to do things we don't expect from time to time. If it were to do it again and/or it caused you inconvenience with your connection then as long as it's within warranty, we would be happy to supply you with a replacement.
Jojo
Jojo
Message 2 of 2
(245 Views)
