Router privileges
Cagney1994
Router privileges
Hi all
What is the highest privilege (if that's the right word to use) on a PN router ? - is it 'PowerUser' or 'WAN_Admin' ?
Cheers.
Fixes: 20
Re: Router privileges
root
Cagney1994
I didn't see that on the options  Huh
dick:quote
Fixes: 20
No I don't suppose you would, but I would have thought Administrator should be sufficient.
Or see: http://npr.me.uk/telnet.html#root
Fixes: 68
What is it you're wanting to do Cagney1994?
I can try and find out if there are any accessible logins above admin but I can't see a reason why that would be needed to be honest
Adam
 Adam Walker
Cagney1994
Quote from: _Adam_Walker_
Hi Adam
I was just curious that's all. When I was with 02, 'SuperUser' was the highest privilege one could have. I was just wondering if 'PowerUser' has the same accessibility as that.
Fixes: 20
I got the impression that PowerUser and WAN_Admin had less privileges than the Administrator account.
Fixes: 6
From command:
mlp role list
Role                Parent              Description
Administrator        TechnicalSupport    Any service and any access from LAN/Local origin only
LAN_Admin            Administrator        Only LAN related configurations from any Channel/Origin
PowerUser            Administrator        GUI(Service/overview page)via http/https from LAN origin
root                -                    The superuser
SuperUser            root                Any service and any access from LAN/WAN/LOCAL
TechnicalSupport    SuperUser            Any service and any channels from WAN
User                PowerUser            GUI(Overview pages, remote assistance) via HTTP/HTTPS from LAN
WAN_Admin            Administrator        Only WAN related configurations from any Channels/Origin
WebsevUser          TechnicalSupport    Webservice access via secured HTTP from WAN
Cagney1994
Thanks for the info, npr.
