Router not arrived
gman1981
Router not arrived
Hi, I have my FTTC install booked for tomorrow (12th July) PM. But have not had my router delivered yet. Can anyone confirm when this should arrive?
Thanks in advance.
Fixes: 4
Re: Router not arrived
Friday morning if you're lucky. If not, you'll have to be patient!  Undecided
gman1981
I have an old router (Linksys WRT54g), will that work if I don't receive the PlusNet one?
jslane
The WRT54G should work as long as you enter all the correct settings. It might be worth flashing that router to DD-WRT too!
