Router manual
- Router manual
Router manual
28-04-2015 4:35 PM
Is there a router manual for TG582n explaining how read the connections stats:Output Power (Up/Down) [dBm]: 12.7 / 0.0
Line Attenuation (Up/Down) [dB]: 11.5 / 28.5
SN Margin (Up/Down) [dB]: 32.0 / 8.8
Loss of Framing (Local/Remote): 9 / 0
Loss of Signal (Local/Remote): 1 / 0
Loss of Link (Remote): -
Error Seconds (Local/Remote): 10 / 0
FEC Errors (Up/Down): 0 / 236,759
CRC Errors (Up/Down): 0 / 0
For e.g. what's the Loss of signal (local) ?
Thanks,
J
Re: Router manual
28-04-2015 4:38 PM
Re: Router manual
28-04-2015 4:54 PM
Re: Router manual
28-04-2015 6:05 PM
Re: Router manual
28-04-2015 6:36 PM
Re: Router manual
28-04-2015 6:44 PM
Re: Router manual
29-04-2015 7:35 AM
DSL Type: ITU-T G.992.5
Bandwidth (Up/Down) [kbps/kbps]: 444 / 9,722
SN Margin (Up/Down) [dB]: 32.2 / 8.9
Error Seconds (Local/Remote): 13 / 0
FEC Errors (Up/Down): 0 / 1,026,533
CRC Errors (Up/Down): 0 / 4
HEC Errors (Up/Down): 0 / 52
There might have been a line test carried out recently (perhaps that's what the loss of signal is). The router was up for 20hrs now (not a new installation).
Thanks,
J.
Re: Router manual
29-04-2015 9:11 AM
Error Seconds are very low at 13 (local), the tg582n tends to over report this, it's no unusual to see this in the 100's or 1000's depending on how long the connection has been up.
The main thing on those stats is your upload speed is locked at 444Kbps, ask Plusnet to unlock the upload speed and you should then see it around 1Mbps.
Re: Router manual
29-04-2015 10:35 AM
Re: Router manual
29-04-2015 5:42 PM
When you post fill stats, always include the Uptime.
If you've recently had a fault and that's been resolved, considering the low error rate then an SNR Reset with an uncapped upstream would be best. If you are a Gamer, ask for Interleaving to be Off as well.
Tony, obviously DPA I assume prevents you from giving the detail of the "problem", but when it's resolved, I'd suggest as above.
Re: Router manual
30-04-2015 11:02 AM
Re: Router manual
30-04-2015 5:42 PM
The router now reconnected at much faster speed:
Uptime: 0 days, 6:38:49
Bandwidth (Up/Down) [kbps/kbps]: 443 / 15,373
Data Transferred (Sent/Received) [MB/GB]: 584.19 / 11.51
Output Power (Up/Down) [dBm]: 12.8 / 0.0
SN Margin (Up/Down) [dB]: 32.5 / 6.1
Loss of Framing (Local/Remote): 27 / 0
Loss of Signal (Local/Remote): 3 / 0
Error Seconds (Local/Remote): 3,455 / 0
FEC Errors (Up/Down): 0 / 0
CRC Errors (Up/Down): 0 / 36,870
HEC Errors (Up/Down): 0 / 41,677
I can see a noise margin is a bit low on the down speed so it will probably drop a bit in the coming days.
However, if the router is connected at 15Mbps shouldn't the speed test come back with the similar speed?
When I run a speed test it still gets around 6.9Mbps/384kbps.
Thanks,
J.
Re: Router manual
01-05-2015 8:18 AM
When your sync speed changes, so does your IP Profile. btw it wasn't your IP profile that was reset it will have been an SNR Reset which sets everything back to default. However this wasn't done with an uncapped Upstream which is why the US speed is only 443kbps (and the larger SNRM that goes with that). If you request it to be uncapped the Target SNRM will then be 6dB for the US, as the DS currently is.
On a 21CN connection such as yours, the IP profile is 88.2% of the sync speed. You can check it by running the BTw Performance test (DON'T REBOOT, ignore the red preamble except make sure no other programs are using the Internet) and at the end of the first run, click the Further Diagnostics button, enter just your Phone number and Run the Further Diagnostics Test. You can Copy and Paste of the results in post here (no need to grab an image).
Your Current Line speed (Login required) also has to match the current IP profile before you'll get the speedtest result you expect. A Delta report has to go from BT servers to Plusnet's system for this to update, and it can sometimes take a while.
Going back to the stats, because you've had an SNR Reset, the default setting means no Interleaving, so you'll note there is no FEC count. In these situations CRC count is always higher. However that CRC count for the Uptime is very high, so I'd expect the automatic exchange DLM to turn on Interleaving to stabilise things at some point. When this happens the connection is dropped and the speed you get will depend on noise levels at the time.
One other tip for now, when things are not quite what you expect, don't go randomly rebooting the modem/router. The DLM will think you have a dropping connection, and if you already have that happening occasionally it will raise the Target SNRM resulting in slower speed.
