Router losing power and connection intermittently
BPanther
Hello,
I have a Plusnet Hub One router but in the past couple of weeks it has been losing connection and flashing orange and in the last week it has been losing power completely. It is intermittent so not sure if there is a fault with the router.
Does anyone have a fix or will I need a new router? If so how do I get one?
Many thanks
2 REPLIES 2
Fixes: 334
Re: Router losing power and connection intermittently
@BPanther Welcome to the forums. From your description, I am going to say your Hub is not 'losing power', more that there is something  affecting your connection. Staff response times are a little extended, so:
BT Broadband(obscuring your phone number) and BTW Performance Tester - Over a wired (Ethernet) connection if at all possible, please report the 'ADDITIONAL DIAGNOSTICS', and sight of the broadband connection status from your Hub (with the 'Username' obscured) would be a good starting point.
For the Hub One -
For the Hub Two -
If you are unsure about anything in this guide, please just ask - I am happy to help.
Fixes: 459
Moderators Note
This topic has been moved from My Router to Broadband
