Router loosed internet Randomly usually in the middle of the night
PeteED
Hi All
I have a fiber connection and it is usually Ok however I occationally look at the log file from the router and it shows a dissconnect and subsequent reconnect a few mins later. These  happen usully in the middle of the night when I am sure it is not me fiddling with the router.
Any Ideas why?
Wulfy
Re: Router loosed internet Randomly usually in the middle of the night
I would suggest this maybe local maintenance at your exchange or maybe a gateway maintenance... plusnet may be able to advise further, I would suggest removing your ip from that screenshot for security reasons
Fixes: 48
The disconnections you mentioned aren't reflected on our systems (as per the graph below)
<img src="http://community.plus.net/visualradius/generated/image13799483503789.png"/>
However unless this begins to happen more frequently or the connection isn't coming back up straight away it shouldn't have any serious impact.
 Adam Walker
