Router lights
tynygongl
Router lights
I have just bought a new router an On Networks 97 N300. In the manual it says that one of the green lights will flash whenever stuff is downloading but all the lights stay on all the time! It works perfectly well. My old router (a Thompson supplied by PlusNet) always had lights flashing but then it broke!! Any comments to satisfy my curiosity would be gratefully received.
pwatson
Re: Router lights
If it works and the lights don't flash then the manual is wrong  Wink
Just ignore this deficiency and get on with life!
NorthEasterner
Re: Router lights
It might be referring to the wireless light.
If it works don't change aanything as it could then become not working
Ex Plusnet Fibre customer. BT Infinity Customer using a BT Smart Hub. If you wish to say thanks, please click the thumbs up Thumbs Up
tynygongl
Re: Router lights
Thanks to you both; I wouldn't/couldn't make any changes; as I said, just curious. Smiley
