Router keeps lagging, anyone know why?
kareha
Every now and then my Billion 7800N decides it will start to lag and I can't figure out why.  This is what it's doing tonight:
Reply from 192.168.1.254: bytes=32 time=315ms TTL=64
Reply from 192.168.1.254: bytes=32 time=1ms TTL=64
Reply from 192.168.1.254: bytes=32 time=143ms TTL=64
Reply from 192.168.1.254: bytes=32 time=164ms TTL=64
Reply from 192.168.1.254: bytes=32 time=149ms TTL=64
Reply from 192.168.1.254: bytes=32 time=99ms TTL=64
Any experienced this before and know how to fix it as it's making gaming a pita tonight.
1 REPLY
Fixes: 9
Re: Router keeps lagging, anyone know why?
Routers do sometimes do that as responding to pings is one of the lowest activity tasks - it doesn't always mean there is something wrong, just that it's got something more important to do. You are better testing to a server in the Plusnet data centre where the gateways are located.
Try pinging ntp.plus.net.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
