Router keeps dropping out and flashing orange
Jamie9
I've been with Plusnet for over a year and I've never had any issues with my broadband until about 10 days ago when the router started intermittently dropping out and flashing orange.
It's been happening daily since then with the internet dropping out multiple times a day. Sometimes it will reconnect and turn blue only to start flashing orange again after a minute or two.
It can go hours without any drop outs so I'm not really sure what the problem could be. I did try resetting the router but that doesn't seem to have helped as it went out for over an hour yesterday evening.
Any advice would be really appreciated Smiley
3 REPLIES 3
Fixes: 357
Re: Router keeps dropping out and flashing orange
If the phone test passes, report a broadband problem via: https://www.plus.net/help/report-a-problem/broadband/
The above assumes you still have 'normal' landline connection - if you have a SOGEA (internet only) one, just use the second link to report a network issue.
Jamie9
Thank you for the advice. I don't have a landline phone so I'll have to go and buy one to test it.
Fixes: 357
Just use the second link in that case - although a cheap corded handset is useful IF you are not on a SoGEA product.
