Router keeps dropping connection
KIBAZ
For the past 2 weeks now i've had problems with my routers connection, it happens all hours of the day and has been having problems daily without fail. Is there a reason as to why it keeps dropping out as it seems a little intermittent. I'm using the hub1 router and package is unlimited fibre. Another quick question i was wondering if plusnet support get involved with any issues people have on here?
3 REPLIES 3
Fixes: 391
Re: Router keeps dropping connection
@KIBAZ Welcome to the forums. the PN Help Team do get involved on here, but are a bit thin on the ground at the moment so most support is from fellow Community members.
BT Broadband(obscuring your phone number) and BTW Performance Tester - Over a wired (Ethernet) connection if at all possible, please report the 'ADDITIONAL DIAGNOSTICS', and sight of the broadband connection status from your Hub (with the 'Username' obscured) would be a good starting point.
For the Hub One -
For the Hub Two -
KIBAZ
@jab1 thank you for the welcoming. I've screenshotted everything needed i think, i couldn't find where to add them in the post but they're in my photo album and you should be able to view them. I also did the noise test which it never brought any abnormal noises and was quiet as a mouse.
Fixes: 391
Thanks for those screenshots, @KIBAZ . To embed them in a post, when replying, click the icon to the right of the 'smiley' and follow the instructions - if you could do that, please, they are much easier to read. Also, can you post your 'Help desk' page from the Hub, obscuring your username?
