Router issues
- Router issues
Router issues
20-01-2014 3:12 PM
I went on my laptop this afternoon and my connection to my router is limited so I troubleshooted it and it came up saying "Your broadband modem is experiencing connectivity issues" but I have restarted it 5 times disconnected the wires put them back in and still the same message?
Message 1 of 9
(1,130 Views)
8 REPLIES 8
Re: Router issues
20-01-2014 4:13 PM
Message 2 of 9
(780 Views)
Re: Router issues
20-01-2014 4:16 PM
stop bumping please and is the problem your internet connection or your connection to the router
Message 3 of 9
(780 Views)
Re: Router issues
20-01-2014 4:19 PM
The troubleshooter said connectivity issues
Message 4 of 9
(780 Views)
Re: Router issues
20-01-2014 4:19 PM
yes but which trouble shooter
Message 5 of 9
(780 Views)
Re: Router issues
20-01-2014 4:45 PM
Windows troubleshooter and when I connect to my router it says "no internet acces"
Message 6 of 9
(780 Views)
Re: Router issues
20-01-2014 4:57 PM
So on the router is the internet light red - I am trying to isolate whether it is a router connection or windows problem
Message 7 of 9
(780 Views)
Re: Router issues
20-01-2014 4:58 PM
The only issue I can see from my point of view Jason is that your connection dropped at around 3pm (just before you posted) and came back about 10 minutes later and seems to have been up since.
Message 8 of 9
(780 Views)
Re: Router issues
20-01-2014 6:26 PM
its working now, dont know what happend there, thanks anyway
Message 9 of 9
(780 Views)
