Router issue
- Router issue
Router issue
4 weeks ago
Hello all, just recently, let's say the past week my router has started dropping out and going through it whole orange flashing light, orange light, blue light procedure up to and possible more than ten times a day. If it is doing any "heavy lifting" such as me playing a game on my PS5 or steaming on my TV it will drop out regularly, this is now becoming unbearable. I have checked all connections and my main telephone socket and all seems to be ok. Any suggestions as to what I can try next? I've searched a few forums and there is a suggestion it's a router problem.
Re: Router issue
4 weeks ago
Is that the Plusnet modem router?
Re: Router issue
4 weeks ago
@Embrangle TBH your problem is much more likely to be a connection fault than a router fault.
Sight of the broadband connection status from your Hub (with the 'Username' obscured) would be of help.
For the Hub One -
For the Hub Two -
Re: Router issue
4 weeks ago
Hi @Embrangle thank you for contacting us through our Community Forum, I hope you are well.
Please can you DM me your account username so that we can look into this further for you.
I look forward to hearing from you soon
