Router help required please
manero
Hi All
I have a very poor w-fi signal from my supplied Plusnet netgear fibre router to my PC with an internal wireless card  - never more than 2 bars (not sure if it's a problem with the router itself as the house laptops connect fine)
Would replacing the router with this help?
http://www.amazon.co.uk/gp/product/B002TOKGL8/ref=s9_simh_gw_p147_d0_i1?pf_rd_m=A3P5ROKL5A1OLE&pf_rd...
Many thanks
Fixes: 25
Re: Router help required please
That router is well reviewed, so much so that I'm going to take a closer look at it.
Whether it will fix your wifi problem depends on your exact problem / house build.  Getting an external wifi card for your computer might be a better solution.  Killer question is with two bars are you still getting adequate through put?
manero
Cheers. It was either that or the ASUS RT-N66U.
In terms of the billion, it looks like a new model is to be released in June:
http://www.amazon.co.uk/Billion-7800DXL-Wireless-Gigabit-Broadband/dp/B00BJ2PCAG/ref=sr_1_16?ie=UTF8...
The price of the Billion BiPAC 7800N may come down as a result.  Smiley
