Router - getting anxious
- Re: Router - getting anxious
20-09-2013 7:55 PM
I applied to join Fibre Essentials on 6 Sept and although I later received an email saying the router had been mailed, nothing has arrived yet and the BT engineer is due on Monday. If the router hasn't arrived by the time the engineer has, is it something I can install myself when it does show up and will he still be able to do his bit without it?
Message 1 of 5
(891 Views)
4 REPLIES 4
20-09-2013 8:50 PM
Hi I experienced the same 'anxiety' in regard to Router arrival however it arrived about two days before the engineer. I am sure it will turn up in time. Hope everything goes well on Monday. Regards, Keith
Message 2 of 5
(455 Views)
20-09-2013 11:32 PM
Thanks Keith. Fingers crossed!
Message 3 of 5
(455 Views)
20-09-2013 11:36 PM
Quote from: Wardio If the router hasn't arrived by the time the engineer has, is it something I can install myself when it does show up and will he still be able to do his bit without it?
Yes to both.
I wouldn't worry its common for routers to turn up last minute, and if for some reason it doesn't, you could always connect your PC directly to the fibre modem and set uo a PPPoE Dialler
Guide here >>> http://community.plus.net/library/broadband/fibre-help-how-to-set-up-a-pppoe-dialler-in-vistawindows...
Message 4 of 5
(456 Views)
23-09-2013 10:04 AM
Message 5 of 5
(456 Views)
